AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
manual property set definitions in dwfx
1 REPLY 1
299 Views, 1 Reply
Is this possible?
I have created a new property set definition and added two manual property definitions and applied this to all objects.
Every object on the drawings has distinct values for these two properties. These property values show correctly on the Extended Data tab of the Properties palette.
I have published to DWFX with AEC property set data set to 'Include'. In the resulting DWFX in Autodesk Design Review I can select each object and see the standard properties but not my special property set data.
Should I be able to achieve this?
Thanks for your help ...
1 REPLY 1
i am having this same behavior today as well. using ACA2012 to DesignReview2013. can somebody else verify please?
”Boost
