I am working with autocad architecture 2011 for magicad. After some days a built panel under home tab missing. I check through CUI , ribbon and expanded home 2d/3d panel. I cannot get(see) build panel. Is there someone help me how can I get the lost build panel.
Emanuel
If this continues to happen to you. Open the CUI editor and click on the transfer tab.
In the panel on the left will be your current ACA.cuix
In the panel on the right either from the pull down or the folder icon open the ACA.bak.cuix. Once open find the build panel in the right panel and drag and drop it in the appropriate place in the ACA.cuix in the left panel.
Another option would be to open the CUI editor and right click on the purple A in the Customize tab and chose to restore the ACA.cui. This will however set it back to default if you have made any changes.
If this continues I would suggest testing another Windows user on the same machine to see if they experience same behavior. If they dont then it could be a problem with you Windows profile as it relates to ACA. Which is a simple fix.
If it happens for all users try doing a repair from the Windows Control panel.
