AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Loss of functionality
2 REPLIES 2
aburgner
348 Views, 2 Replies
I have a strange one...  Someone came to me this morning and stated that they cannot perform any actions after some time in AutoCAD Architecture 2013 - no zoom, pan, select, etc.  However, functionality seems to return if they perform a save command or close the software.  Any thoughts as to the cause or the solution for this one?
Thank you for any guidance you may provide.
2 REPLIES 2
Steve_Bessette
in reply to: aburgner
Have you tried to reset the default settings for the program?  This can be done by (for Windows 7):
  • Click Start
  • Select All Programs
  • Select Autodesk
  • Select AutoCAD Architecture 2013
  • Click "Reset Settings to Default".
This will bring up a dialog box where you are asked if you want to save your current settings to a .zip file or to just proceed with the reset.  Once the reset is completed, the program will reopen.
Steve Bessette
Support Specialist
Product Support
Autodesk, Inc.
aburgner
in reply to: Steve_Bessette
Due to other problems on this machine, I have performed a complete clean install of the software.  I am hopeful that this will fix numerous performance issues on the computer in question, including the loss of functionality described.
”Boost
