We have company tool palettes set up in catalogs on the server. I was able on "load and existing catalog" on a users machine this morning but when I try to drag and drop the catalog palettes to the tool palette, nothing happens. They don't populate the palette and they do not show up as an available tab under "customize". Has anyone else encountered this?
Solved by David_W_Koch. Go to Solution.
Thank you David!
All of that is correct. We are using ACA 2012 and working through the Content Browser. For some reason the user came in this morning and had lost his profile (system wide) so we had to reset up ACA. Loading his saved profile fixed everything except for the tool palettes. I had forgotten to check that under Options. Once I repathed to the correct folder on the server, his palettes showed up at least under the "customize palette" dialog and I just had to drag them into the correct palette groups. Those were read only folders, which I changed to give him read/write access, but the i-dropper still would not pull from the catalog. The AcTpCatalog.atc is located in the tool palette folder.
So, I did get him working with company palettes again at least, just never resolved why the i-dropper is not functioning.
