AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Lineweights: Convert multiple lines to same lineweight
2 REPLIES 2
1266 Views, 2 Replies
Hi guys,
I'm trying to select over several lines (they currently have different line wieghts) and want to change all to a .05mm lineweight. For instance, I have imported floor plans from revit where the walls are outlined in .70mm lines. I am able to select one, double click it, and change the lineweight but if I select several and double click them, the option to change the linewieght is not offered. I have tried changing them to a layer that has a linewieght of .05mm but the .70mm linewieght remains.
Please let me know, thanks!
Tags (1)
2 REPLIES 2
Laks-Autodesk
Select the lines you want to modify and in the properties palette, change the value of the lineweight (it will show *VARIES* if they've different lineweights). This should change the lineweight of all the selected lines.
Lakshminarasimhan Seshadri
in reply to: Laks-Autodesk
Awesome, that's exactly what I've been trying to figure out for some time now. So far the only way a know how to ge the properties panel open for multiple lines is: double click one line and leave the properties panel open while I  then select over multiple lines. Easy enough, thanks!
”Boost
