Good Morning David:
I have "sort of" the same problem but it is more general in terms of a local office of a big corporation using different layers/ctb files. We have been instructed to utilize the same ctb file/lineweights as the corporation does.
I am going to bullet your comments to make sure I understand what you have written and ask for clarification on some.
Generally: Plot Style (CTB or STB) settings govern.
If the plot styles are set to use object lineweight, then the drawing settings come into play. Drawing Settings: Meaning "Layer settings"?
If all of your objects are set up to be lineweight "ByLayer" (or, for nested objects, "ByBlock"), then the lineweight setting on the layer (as viewable in
the Layer Manager) will govern.
If individual objects (or, for AEC objects, individual components) have hard-coded lineweights, then those will govern, not the layer settings.
Thanks in advance for your patience and your assistance.
Larry
Drawing Settings means just that, Drawing Settings. If a lineweight is set in the Plot Style, then that is what will be used, regardless of any settings in the drawing. If the Plot Style is set to use object lineweights, then the effective lineweight set in the drawing will be used, based on the following heirarchy:
The lineweight set on a main object's layer will be applied, if the lineweight of the main object is set to By Layer.
If a specific lineweight is set on a main object, then that lineweight will be applied, not the layer lineweight.
Objects nested within "complex objects" have an additional possible setting, By Block. Complex objects include block references and AEC objects that have components.
