AutoCAD Architecture General Discussion
Valued Contributor
calfcreek_2
Message 1 of 5 (119 Views)
Line Type Scale behavior
119 Views, 4 Replies
12-30-2009 08:24 AM
I am using '09 and in the past I have always set the lts to the intended plot, IOW for 1/8" I would set the lts to 96, then draw and set lines to look like I wanted. Then in PS I would set the lts to 1 and all would look fine. Lately, on some sheets this does not work. There doesn't seem to be any rhyme or reason. Just some sheets don't look right and we just have to adjust the lts in PS until the desired result is shown. Many times this ends up being the actual lts i.e. in this case 96 in PS. This doesn't happen with every drawing. Strange!
Is there a variable or something that sets the behavior of the lts?
Thanks in advance.
Keith D. Rodebush
*Anthony Mason
Message 2 of 5 (119 Views)
Re: Line Type Scale behavior
12-30-2009 09:00 AM in reply to: calfcreek_2
MSLTSCALE was introduced in version 2008. Set it to 0 to match the old
behavior.
That said, I recommend setting MSLTSCALE, PSLTSCALE, LTSCALE, and
CELTSCALE all to 1 and letting viewport and annotation scale determine
linetype scaling.
> Thanks in advance.
> Keith D. Rodebush
Anthony Mason
http://dailyoccurrence.wordpress.com/
Valued Contributor
calfcreek_2
Message 3 of 5 (119 Views)
01-04-2010 07:30 AM in reply to: calfcreek_2
Thanks Anthony.
So you are saying that if I do that then I keep LTS to 1 and set drawing scale to plot scale and draw to suit?
That sounds a lot easier if it works right.
Thanks again for responding.
Keith D. Rodebush
*Anthony Mason
Message 4 of 5 (119 Views)
01-04-2010 08:47 AM in reply to: calfcreek_2
That is correct. The only problems I've seen have been caused by an
object linetype scale other than 1 (usually 0.04166 here).
On 1/4/2010 7:30 AM, calfcreek_2 wrote:
> Thanks Anthony.
> Keith D. Rodebush
Anthony Mason
Valued Contributor
calfcreek_2
Message 5 of 5 (119 Views)
01-04-2010 02:00 PM in reply to: calfcreek_2
Thanks.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
