AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Line Type Scale behavior
4 REPLIES 4
calfcreek_2
285 Views, 4 Replies
I am using '09 and in the past I have always set the lts to the intended plot, IOW for 1/8" I would set the lts to 96, then draw and set lines to look like I wanted. Then in PS I would set the lts to 1 and all would look fine. Lately, on some sheets this does not work. There doesn't seem to be any rhyme or reason. Just some sheets don't look right and we just have to adjust the lts in PS until the desired result is shown. Many times this ends up being the actual lts i.e. in this case 96 in PS. This doesn't happen with every drawing. Strange!
Is there a variable or something that sets the behavior of the lts?
Thanks in advance.
Keith D. Rodebush
4 REPLIES 4
in reply to: calfcreek_2
MSLTSCALE was introduced in version 2008. Set it to 0 to match the old
behavior.
That said, I recommend setting MSLTSCALE, PSLTSCALE, LTSCALE, and
CELTSCALE all to 1 and letting viewport and annotation scale determine
linetype scaling.
> Thanks in advance.
> Keith D. Rodebush
Anthony Mason
http://dailyoccurrence.wordpress.com/
calfcreek_2
Thanks Anthony.
So you are saying that if I do that then I keep LTS to 1 and set drawing scale to plot scale and draw to suit?
That sounds a lot easier if it works right.
Thanks again for responding.
Keith D. Rodebush
That is correct. The only problems I've seen have been caused by an
object linetype scale other than 1 (usually 0.04166 here).
On 1/4/2010 7:30 AM, calfcreek_2 wrote:
> Thanks Anthony.
> Keith D. Rodebush
Anthony Mason
calfcreek_2
Thanks.
”Boost
