LAYERP won't work for me. It just tells me that there are no previous layers saved after I go through an entire of exercise of freezing layers. I have LAYERPMODE turned ON. I tried freezing and turning off and neither get a result. Please help?
Command: _LayerP
*No previous layer status*
Command: layerpmode
Enter LAYERP mode [ON/OFF] :
Command: _layoff
Current settings: Viewports=Vpfreeze, Block nesting level=Block
Select an object on the layer to be turned off or [Settings/Undo]:
Layer "DIMS-720" has been turned off.
Layer "ASE-08" has been turned off.
Command:
Command:
Command: _layfrz
Select an object on the layer to be frozen or [Settings/Undo]:
Layer "GRIDBUB-192" has been frozen.
Layer "DIMS-048" has been frozen.
Layer "DIMS-192" has been frozen.
Layer "GRIDBUB-048" has been frozen.
Command:
Command:
Command: _LayerP
