Currently I am AutoCAD vanilla user only but couple of years ago I worked in firm using ACA with add-on developed in Germany.
I don’t know what controlled it (ACA or add-on) but layer visibility (On/Off and Freeze) was saved within each Layout tab.
Say, you could turn off or freeze layers in Model space but it won’t effect layers visibility in Layouts.
My question is: Is this feature from of ACA? Could someone check it for me?
Thank you.
Richard
Solved by Gary_J_Orr. Go to Solution.
Hi Gary.
Thank you for your reply. I had little hope that ACA has this capability to keep layer on/off property independent for each layout tab.
I have to probably play little bit with layer state then.
Richard
