When I click on Layer Properties Manager, I do not get the layers palette. The same goes for typing layerpalette in command.
Thank you.
Solved by tschau3. Go to Solution.
It could be coming up off the screen somewhere. Try this: Alt + spacebar > M, and then use your arrow keys to move it back to your screen.
When I click on Layer Properties Manager, I do not get the layers palette. I can get it by typing 'classiclayer' or 'layerpalette' commands. Any solutions. I am working in AutoCad 2009.
thank you.
In 2012 the "classiclayer" command works great, but "layerpalette" does not. It is working, but you have to click in each field to see the box (like white text on white background). This makes it nearly impossible to work with, but "classiclayer" can handle most of the needed functions. Also using Windows 7, and haven't updated AutoCAD 2012 online at all since release. Perhaps this problem has been fixed.
Attached image to show better. The classlayer is seen in front with all the layer, while the layerpalette behind appears to be blank (you have to click on each cell to see something, which then disappears after another cell is clicked).
I experience this exact same problem intermittently. Have you discovered a fix?
I am running AutoCad Architecture 2012 on Windows 7 Professional with nVidia GT 440 on 2 screens. ( keep all of the AC functions on one screen).
-Frustrated
-Frustrated
Having tha same problem with AutoCAD 2015. "classiclayer" command works but you can't dock it, which is inconvenient. I will continue looking for a fix. It was happening intermittently, and I would simply restart the program. Now, it happens continuousy.
Why is Autodesk so incompetent at managing all the various windows that are needed to use Civil 3D? How is it possible for a window like Layer Properties Manager to dissappear off screen? The Alt+spacebar>m and arrows trick does not work to bring it back. Why doesn't auto-hide work? When it does work it takes forever to gtf out of my way! Unchecking auto-hide undocks the window! Now Autodesk's incompetence is causing me to waste time trying to get it back. The Knowledge Desk solution to delete the Layer Manger registry key did not work either!
The only way to get my Layer Properties Manager window back was to hover my mouse at the edge of the screen until the cursor changed to the resize tool, then drag the edge of the wayward window onto the screen. After restoring all docked windows where I had them before I locked them and all my toolbars into place by entering LOCKUI on the Command line and changing the system variable to 15 (combination of all locked options).
If you are new to Civil 3D, as I am, it is helpful to know the LOCKUI system variable and its options:
I just had the same problem 1-9-2017. I tried the CLASSICLAYER and got a Layer Manager on screen. Did that a couple of times and then I noticed that my Button on the Panel finally started working again. Prior to that when I tried the button I just got black bands across the screen.
Don't understand why, I got it working again, but was definitely a frustrating moment.
Thanks for the help
Another sure fire way of resolving this is to right-click on a column heading and select at the bottom 'Restore all columns to defaults'.
Works everytime 🙂
I had the same issue and none of the proposed methods resolved the issue for me. What I ended up doing to fix it:
1. Close out of all Autodesk apps and services
2. Delete the Autodesk folder located here C:\Users\<Username>\AppData\Local\ folder (View -> Hidden Items must be enabled to see the AppData folder)
3. Launch AutoCad
This resolved the issue for me. The user will have to re-do their preferences as those are wiped along with that folder.
System info:
Windows 10
AutoCad Lt 2018
I think the fix for this is to go through the CUI interface, go to your current workspace, once the contents is showed on the right-hand side, go to palettes, then to layer property manager, then under the appearance, change the orientation (to left or right) and docking to 'yes' and show to 'yes' if you want for good measure, apply, and hopefully all is good and it now appears. If not, you may want to change your workspace to another and then flick back.
From there you can stick it where you wish, so to speak 🙂
Just got a new laptop that has Autocad v2017 loaded and am absolutely disgusted with obnoxious changes that have cost me hours to overcome and still can't get the layer properties palette to operate as it did before.
I do a lot of editing across all the layers, so in my prior v2015 I left the palette open (NOT hidden)
I was eventually able to get the layer palette to dock but it's default status was set to auto-hide and when I attempted to turn that off, it undocked EVERY TIME.
I have followed some other instructions and got what was referred to as classic layer, (a dialog) but that is not the same as the layer properties palette, as the 'classiclayer' is seen by acad as a tool that has to be exited, not left open.
