I'm not sure why you are still seeing the layers, even though they are
grayed out. When I create a new layer filter similar to your's, I only see
the host drawing layers in the drop down list. Do you see the same results
if you use the invert option, even though you don't want to use that option?
Doug
"scarrillo2023" wrote in message news:6334254@discussion.autodesk.com...
Doug,
I'm using AutoCAD Architecture 2010... I never used 2009.. Invert filter
is an option that I don't want checked in my layer Manager...However I
created a new layer filter group named No Xref.. I used "~*|*"
which exclude the X-Ref layers and that worked for me... The only problem
now is that in the quick properties/Layer drop down It still gives me all
layers only now it greys out the Xref Layers... I still don't want to see
all layers in my quick properties box... If I hit the Home tab and try to
change the layer there it works?????????????
