Friends,
I have changed the color of some of the xref file layer in my drawing manually from the layer manager. Is there any way of getting the original color back without detaching and reattaching the xref's in a quick way?
Riznas
Solved by David_Knight. Go to Solution.
Solved by David_W_Koch. Go to Solution.
You could set VISTRETAIN to 0, save and close the file and then reopen it. Assuming you want the file to "remember" the externally referenced layer settings from that point forward, you would then reset VISRETAIN to 1.
NOTE: That will affect all settings on all external reference files, including viewport freeze state. If you have a lot of settings you want to keep and only a few colors to change, it may be easier to do so manually.
As a quicker (and potentially safer method) you can set Visretain to 1, then reload the individual Xref that you want to change back to the original settings, then set Visretain back to 0.
Reloading the file resets EVERY xref, which could be a problem if you have more than 1 Xref in the drawing you are using. The way I described it would only reset the one reloaded Xref file.
