AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Just-in-Time error
5 REPLIES 5
rfrisch
5220 Views, 5 Replies
Just-in-Time error
Hi Everyone:
   I have a problem. Every time I open R9 Architectre this morning I've been getting an unhandled exception error. It says "Unhandled exception has occured in a component in your application. If you click Continue the application will ignore this error and attempt to continue." Then it says  "Invalid URL scheme is not valid". Then in the box below "Application does not support Just-In-Time (JIT) debugging. See the end of this message for details'. Then I scroll down to the end and it says "Application does not support Windows Form just-in-time (JIT) debugging. Contacct the application author for more information".
   I shut down Autocad then my computer (twice) thinking it was just a glick. Well here I am, "Help Me". Thanks and have a nice weekend.
5 REPLIES 5
pendean
in reply to: rfrisch
Did your security level change in IE (or Windows) over the weekend? Ask yout I.T. folks and put it back.
rfrisch
Hi Dean;
    I just checked out my security on IE and the security hasn't changed but when I opened Autocad the message didn't pop up this time. So I rebooted my machine to see if the message would replicate when I opened Autocad again, but no message. This is weird. Thanks for you help. Have a nice day.
Ray
dbd63
in reply to: pendean
What is Just-in-time Debugging?  I'm reading the message about it now, after crashing apparently.  It says that to enable it, "the .config file for this application or computer (machine.config) must have the jit Debugging value set in the system.windows.forms section".  I've not heard of these files, and it sounds like something only a knowledeable system administrator should set up.  Do I want jit Debugging?  Is it something I should ask our IT guy to consider setting up?
pendean
JIT is triggered by a security setting change on your PC, Windows or browser: your IT should the able to figure out what changed on your PC since it last worked. This is a common windows security issue with many software, don't cloud it by asking them to do anything else.
jeff
JIT debugging is usually enabled when you install Visual Studio.
By looks of the error try turning off communication center
You can also find your answers @ TheSwamp
”Boost
