AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Is this another bug in ACA2015 - Dashed lines in spaces don't display.
5 REPLIES 5
ntellery
589 Views, 5 Replies
It could be a setting I am missing but open the attached file in ACA2013 and my spaces show hatched lines.
Open in ACA2015 and the hatching no longer displays.
Been wrestling with this for a while thinking my settings were wrong but it seems not. 2015 is broke.
www.ausaca.blogspot.com
Do you know all about the Roof Object? Learn it's secrets
http://ausaca.blogspot.com.au/p/roof-object-video-links.html
5 REPLIES 5
Laks-Autodesk
in reply to: ntellery
Hi Nathan,
Thanks for reporting this issue.
I've logged it with our development team.
Lakshminarasimhan
Lakshminarasimhan Seshadri
tedwardspg
edit object display. Turn on hatching.
ACA 2013
Windows 7 enterprise
Intel core i7 860 @ 2.80GHz
16GB RAM
NVIDIA Quadro FX 1800 - 4GB
ntellery
in reply to: tedwardspg
The hatching is turned on. It's the diagonal lines showing.
Laks-Autodesk
This seems to be due to the new sysvar introduced in AutoCAD 2015 HPLINETYPE which is set to OFF by default, to improve performance. Turning this sysvar ON should make the hatches show the linetype.
ntellery
in reply to: Laks-Autodesk
Yes that was it, thanks.
”Boost
