Hello, I have been using Digimap for some time now, but the Mastermap download always fails on me in AutoCAD Architecture 2012. The download process in fine, along with the conversion to .dwg format, when it's in AutoCAD program the problems occur. For a start the file is now in imperial (inches) units, and I have spoken with EDINA and they have no idea why it is like this, as it should be in metric (mm). This would fine fine if I could change the units, but it is not that simple. On changing of units to mm, and clicking yes on resizing, the modelspace drawing disappears. I can only view it if I use 'Zoom - Extents', but then the drawing is now extremely out of scale, being over 50% smaller than the real life counterpart.
Has anyone else had this problem, or does anyone know of any solution? Both Dotted Eyes & Edina have been of little help at any stage, so hopefully I can find a solution on here.
Thanks in advance,
Matt Palmer
Solved by David_W_Koch. Go to Solution.
EDIT: It is often 30-40 times smaller than it should be, not half. Also I could just use the Scale factor command, but it risks inaccuracy and is very tedious, so any solutions would be preferred. Thanks.
