I have just installed my new 2015 AutoCAD Architecture upgrade (from a mailed media box set)
A shortcut to AutoCAD 2015 appears on my desktop and opens successfully,
But no shortcut to AutoCAD ARCHITECTURE 2015 appears, and I cannot find it under my list of programs
Where is it? How do I open it?
Did the boxed set only contain AutoCAD Architecture, or was it for one of the suites? All three variants of the Building Design Suite (Standard, Premium and Ultimate) include both AutoCAD and AutoCAD Architecture. Could you have installed AutoCAD 2015 rather than AutoCAD Architecture 2015?
Hi Bruce,
Could you please check the following location and verify that the program is installed (see image below)?
If the program doesn't show up in this list, then it is not installed, and you will need to install the program from your Building Design Suite media.
Hi Victoria,
It does show Autodesk AutoCAD Architecture 2015 English listed in the intalled programs, as you suggested.
What should I try next?
Hi Bruce,
From there, you can double-click the program to launch the utility to add/remove features, repair, reinstall, or uninstall the program.
Choose "Add or Remove Features".
Check/uncheck all of the content packs you do or don't need installed (US Imperial, US Metric, and Global are the default).
Choose "Next" then "Update".
A separate shortcut for each of the content packs you checked should now appear on your desktop.
I double clicked on the icon listed under programs, and it begins to launch Acadarchitecture 2015, and then crashes with this note;
Failed to load
c:\users\admin\appdata\local\temp\_aic88c.tmp\setup\contentpackui.dll(126)!
I have reverted to acadarchitecture 2014 to get on with my work- but as of this morning it wont open, with the following notice;
FATAL ERROR; Unhandled c00000fdh Exception at fede4887h
Acad 2015 opens and works fine, but its acad architecture that I need as my existing drawings all have intelligent walls, doors, windows etc. I really need to get on with my work but I am now properly stuck.
Please help
Bruce
And when I try to reinstall acadarchitecture 2014 is cancels and does not complete
And I cannot even begin to reinstall acadarchitecture 2015 because when I double click on it, it crashes before the screen comes up giving option to repair/reinstall
I also tried the repair button on 2014 acadarchictecture-
it said repair was successful
but the program still crashes before it completes launching
