AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Inserting doors offset and / or centered
2 REPLIES 2
1069 Views, 2 Replies
I've just upgraded to ACA 2012.  I can see how to insert a door in either an offset "or" centered position, but not both.   In my previous version, the position could be set to "center / offset" which was an "and / or" option depending on the cursor location.  Is this option available in ACA 2012?
2 REPLIES 2
David_W_Koch
No, this changed in ACA 2011, as part of an expansion of the options when inserting a opening (Door, Window, Door/Window Assembly, Opening).  If you are interested in more details, I wrote a series of blog articles on the change.  Here is a link to the first article; there are links to the next article at the end of all but the last article.
http://architects-desktop.blogspot.com/2010/10/aca-2011-opening-location-changes-part.html
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
David,
Thanks for the reply and link to your article. Bummer that function is no longer, but at least now I know to stop looking for it.
Cheers,
”Boost
