AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Insert a sheet list in ACD-A 2010
3 REPLIES 3
368 Views, 3 Replies
Good morning,
I use ACD-A 2010 since this summer... I used to insert a sheet list on prior version of ACD-A. Right now, with the new version, i'm not able to insert it. The process is the same but nothing append. Alos on the second tab of the Sheet list dialog box, the drop down menu always indicate "none selected" but I try everything... select the file manualy, check everything ... nothing?
Please help,
thanks,
Stéphane
3 REPLIES 3
Also, there is what I tried so far:
- Select the subset and insert the sheet list = nothing
- Select the entire sheet set and insert the sheet list = nothing
- Select all sheets from the entire set and insert the sheet list = nothing
- Create a new template for the table
- Use ACD-A template to insert the table
- stand up, touch my nose and turn 3 time clockwork.... still nothing
Do we have to say a magic phrase or I'm just stupid? (please don't answer that one)
S.
JTBWorld
Make sure that one of the sheets in the sheet set is the current drawing opened and then right click on the tree view (Sheet Set View) and you should be able to insert the sheet list.
If you just have any other drawing opened you will not be able to insert the sheet list.
Jimmy Bergmark
JTB World
http://www.jtbworld.com
Sheet Set Manager Properties Editor
http://www.jtbworld.com/SSMPropEditor.htm
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
mikeshick
I've got the exact same problem.  Been inserting sheet list for several years.  Suddenly, I cannot get it to appear on anything.  I've done just what the OP stated...even patting my tummy and doing whooop-d-dos on my desk...still can't figure out why my list will not import anymore.  Any Ideas?
Mike Shick
www.medesigns.us
”Boost
