Look around both ADT/ACA discussion areas, this topic is covered every time
there is a new DWG format.
And yes, all you have to do is SAVE in the newer version, regardless of what
SAVE is set to for format, to upgrade AEC content and remove them from the
lower version. Again, this is only for AEC content, nothing else.
If you see 'destruction' in anything else you will need to post a DWG file:
we all have your versions and we can see your files.
Dean Saadallah
http://LTisACAD.blogspot.com
