AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
I've changed a setting or something and can't change it back
2 REPLIES 2
migdalia_banda
242 Views, 2 Replies
So I dont know how, but a couple of days ago while I was drafting, I must have clicked some extra keys or something
because now when I try to individually select multiple lines the program alternates [as in releases one to grab the
other] instead of simplying adding that line to those already highlighted. Its very fustrating as I like to type in my
shortcuts of the commands and like to draft at a quick pace. Does anyone know what I did or how to change it
back? I'm also all for resetting the "defults" if it means fixing the problem.
2 REPLIES 2
tschau3
in reply to: migdalia_banda
PICKADD got turned off.  Set back to 2.
migdalia_banda
in reply to: tschau3
YES! thank you so freaken much! totally worked!
”Boost
