Newbie here on 2015 version, day 2 of learning.....
I've been googling and watching videos, but so far, I've not seen answers to how to do these few things.
1. On the attached image, I am trying to move the entire segment of walls on the eastern side in with one command to shorten up the width of the area. Surely there is a better way than selecting each segment and reducing them individually by the same amount, isn't there?
2. On the above, what is the red circle? It appeared after I played with 3d.
3. When I use the AREA command and select Add, then pick all my points, it then tells me the square footage. That's great, but each time as I modify the drawing, I have to reselect the same area over and over. I'm sure there is a way to make it remember the area and adjust it each time I move the location of a wall, isn't there?
4. How do I get it to automatically always show interior dims? I want exact wall lengths. I don't want it compensating for halfway into the walls, etc. I do the measure, but it does not remain on screen when I move on to the next segment.
5. Just like #4, except I would like to see the exterior dims.
6. Right now, my dwg is set with 3" exterior wood frame walls. If I later on change it to cement or some other substance that is much thicker, will I be able to control it so that the widths of all the exterior walls expands outward and not inward? Is this a one fell swoop, select all the exterior walls and make the change process?
7. Any best beginner videos (youtube, etc) that you would like to recommend? I'm a very good hands on learner, especially with videos, which is how I am learning it now.
Thanks so much for any help or suggestions.
Dusan
answer briefly...
1. Start by creating your wall styles. Styles can be applied to one or all walls
2. Use "SpaceAdd" command. Space is automatically changed with the change of walls
3. Use "AEC Dimensions Styles" to automatically track the size and position of the walls
Vitaly
Thank you very much! I will read up on these new commands/concepts and check out the videos. 🙂 I'm already playing with the new SPACEADD.
Thanks guys for being so helpful to this self taught newbie!
