AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
How do I stop multiple sessions of Autocad opening?
4 REPLIES 4
StubbesPrecast
540 Views, 4 Replies
I am running AutoCAD 2006 LT and AutoCAD 2010 on one computer and have the SDI set correctly. When I open multiple files from Windows Expolorer, it opens multiple AutoCAD sessions. How to avoid this from happening?
4 REPLIES 4
pendean
in reply to: StubbesPrecast
What is WIndows Explorer set to use to open DWG files? right-click on a DWG file, select OPEN WITH and find out. It should be ACLAUNCHER.EXE for what you desire (how it works on our PCs).
By the way, neither of your programs is AutoCAD Architecture, the furm is dedicated to this version of AutoCAD only, why are you posting here?
StubbesPrecast
in reply to: pendean
Thanks, I will give that a try.
The reason I am posting in this forum is because I am using AutoCAD Archtecture 2010.
pendean
Thanks: it helps if you use that name instead of just 'autocad' as there are ARCH (or ACA as others call it) tools not available in plain AutoCAD.
StubbesPrecast
Still the same issue...
”Boost
