Been trying to do this for about four hours now.
Solved by ntellery. Go to Solution.
Solved by pendean. Go to Solution.
Just to add to Dean's tips.
If your layout tabs are not visible, go to OPtions, Display tab and bottom left, tick Display Layout ..tabs
btw you say drawingS?? Working between drawings involves using x-refs.
When you create a view (MVIEW) in display tab paper space, you create a hole that looks back into model space. (if you don't understand the whole paper space thing).
You can also set the scale of the viewport by selecting it and looking at the properties pallete.
