AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
how do I change the number of treads using the stair command?
1 REPLY 1
jools182
258 Views, 1 Reply
It seems to be set at 17 but I can't find a way to change it
Autocad help is no help at all as it says change the field to a user defined one, whilst not actually telling you how to do that
cheers
1 REPLY 1
ntellery
in reply to: jools182
When stair is selected, Check the properties pallete - Calculation rules, click on the box next to Tread, and a box opens where you can play with different componants.  Some are locked but can be unlocked to edit.  There are relationships that must be kept.
 The stair object is not a simple object but take a look in the style under Design Rules and see if the "Use Rules Based Calc" is checked.  If yes then you are restricted to conform to those rules.
www.ausaca.blogspot.com
Do you know all about the Roof Object? Learn it's secrets
http://ausaca.blogspot.com.au/p/roof-object-video-links.html
”Boost
