Created roofs then converted to roof alabs. The pivot points are on the top of the slab. How can I change them to the bottom, where they should be? Thanks - John
Pick them up and move them to where ever you want. Personally I place it on the junction of the wall plate however once the angle has been decided then I can move the roof slab up and down.
Thanks. One would think that the pivot point would default to the bottom of the slab, on the outside face of the wall...maybe we need to create a style that does....John
