I have an issue where any hatch that I place on a tool palette comes in on the wrong layer. They all come in on the a-hatch-window layer despite the properties of the tool being set to the correct layer and the correct layer being present and being the current layer in the drawing. Anyone know why?
Solved by Libbya. Go to Solution.
Here are some screen captures.
The first "layers" shows the layer mager and the correct layer A-hatch-conc exists and is in the current drawing.
The second shows the tool properties and "A-hatch-conc" is selected as the layer the hatch should go on.
The third "tool activated' shows the image when the tool is selected. At that point it shows the color of the correct layer.
I can only do 3 attachments per post. See you soon...
And here's the final screen capture.
"Wrong layer" shows that when the hatch is created it is placed on the layer 'A-hatch-window'. FAIL!
What's up with that??
