AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Hatch within wall not joining?
2 REPLIES 2
381 Views, 2 Replies
Good day all,
Another little problem off the big list.  Up until now i have been using Autocad Architecture 2009 but recently upgraded to 2012.  For some reason though, my hatches are now no longer linking on wall corners like the attached drawing shows.
Can anyone give me a hand here?  Been trying to fix this for a while now with no luck at all.
Thanks in advance
Steven Young
2 REPLIES 2
David_W_Koch
Check your Display Settings to see if the hatch component shown is set to align "global" or "object".  Global should get the hatches between two different but intersecting objects to align.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
in reply to: David_W_Koch
Thankyou for your reply David,
I checked that both sections of the wall were the same, and both walls were set to global already.
The strange thing is, when i originally designed the dwelling in 2009 the hatches were fine, but now in 2012, i have this issue.
”Boost
