I would like to know how i can find the good scale for hatch. Is there an other mean to find by aleatory ?
David G.
My question concern all Hatch in autocad architecture. I would like to know if their is a rule to put the good scale for each hatch. My teacher told me that you have to try to find the goo scale. Is it true or if i can follow a rule???
David
Not ALL hatch patterns have the same principle/scale option, so go back to your teacher and ask a more detailed question. Hatches are coded differently based on a pattern someone somewhere wanted to use at the time.
You can start exploring on your own (what your teacher probably wanted you to do) by hatching and manually measuring to find a method that works best. Good luck.
