I am working on my electrical plan with the floor plan xref'd. I am able to get the entire floorplan to plot lighter using the 25% saturation feature in layers. The walls print ghosted, but the hatch that is on the same layer as the walls stays dark. I tried creating a seperate wall section All layers on the floor plan dwg that are xref'd in are the same in the layers dialog. Any suggestions? Is there any way to turn the wall hatching off in the xref?
Solved by MarySeufert. Go to Solution.
Solved by ntellery. Go to Solution.
Could you use the reflected display rep that is designed for service type drawings.
That DR doesn't have the any wall hatching showing.
You can also click on the xref and right click to get an override display rep just for the xref if that is helpful.
In addition to the 'Reflected' Display rep ntellery mentions, you mgiht want to try the 'Screened' and 'Screened Reflected' Display Reps.
~ Mary
