I have the same issue too. Same error in my event viewer and another message in the Autocad windows :
"Not enough memory to run Autocad LT. if you continue the current operation, there may be a bug or data loss. Cancel the current task?"
It could be a RAM problem, or not?!
Point out that the RAM available is 2 GB (it is used about half) and Autocad version is AutoCAD LT 2009 ...
Thanks a lot!
