Solved by danellis2982. Go to Solution.
Any reason why you can't draw them as separate slabs and give them appropriate elevations (using the TOP or BOTTOM values, depending on how your slab style's defined).
The trick will be selecting a suitable CUT PLANE. A value of 1800-2100 would equate to 1350-1650 in the dining room and bedrooms and 1050-1350 which *should* work for both levels.
dJE
