AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Grid line issue with Schedule Table
5 REPLIES 5
ted.evans
404 Views, 5 Replies
I have set up a schedule table in ACA 2013 using the new group feature. I only want the total line visible but the other lines wont turn off. The attached files shows the table and the diplay settings. Does anyone have a solution for this issue or is it a bug with the group feature?
5 REPLIES 5
cadtastrophe
in reply to: ted.evans
You should be able to edit this in style manager.
ted.evans
in reply to: cadtastrophe
Tried that but when I turn all grid lines off white column lines appear
cadtastrophe
Can you post your drawing?  I tried in several different drawings and had no problem turning off column or row grid lines in style manager.
ted.evans
Here is the file
cadtastrophe
Ted,
I apologize I wasnt able to get to this, I do not have 2013 on this machine, I will try to get to a machine with it on there today.  In the meantime hopefully someone could open up that drawing and give it a go.
Jeff
”Boost
