Is there a way to change the color in the layout tab behind the sheet area (the grey area).
i can chage the paper area but just wonder if there is a way to chage the area around it,
its hard to see viewports in this area
so i want to make it darker
thanks
I don't know of a way to alter that color, but under options->display you can un-check the 'Display paper background' option. Then your whole layout tab is a uniform color.
~ Mary
i can not find that option display to uncheck ... do you know where that is ?
Thank you...
i Am just wondering are there setting for that now ... you would figure that you would be able to edit the color or something ...
Thanks again for letting me know where that was tho!
gf
