Trying to finish someone else's half finished project done in acad 2007. I'm working in Architecture 2009. I just opened a sheet template, xreffed the file into a viewport, and whenever I switch from model to paper space or back I get this message-
Cannot find the resource string number 25900 in resource AecXDisplayPropsData50-
It's driving me crazy! Anyone know what this is or how to resolve.
Have you tried to repair any of the files with RECOVER or AUDIT (you have to do it inside each file)?
Thanks for your reply Dean. Yes I did try Audit to no avail. I searched this on google and found one person's solution to be to toggle back & forth on profiles and it went away. No such luck for me. Still having the issue.
Those kinds of problems can sometimes be fixed by 1)doing a repair install or resetting the ACA application, 2)not saving back to an earlier version, and 3)not upgrading individual ACA files.
I usually keep working on a project in the same version it was created in until finished. Upgrading usually causes detail component manager problems. Might be the relationship between the tooltip information coming from a database that doesn't have the same keys as the newer version.
Are you using Project Navigator? I use that to place views on sheets instead of xreffing.
