AutoCAD Architecture General Discussion
Active Contributor
jking
Message 1 of 15 (6,555 Views)
Get the AutoCAD "Properties" Panel into the ACA2012 Ribbon.
6555 Views, 14 Replies
05-12-2011 10:53 AM
How can I modify the line type/weight? How can I change the color?  Where are my object properties?
I have seen a few threads with variations of these questions.  I had the same ones, until now.  I did some serious messing around and came up with this, I thought it may be useful:
To get the AutoCAD 2012 "Properties" panel in ACA 2012:
Disclaimer:  This procedure involves modifying your software's configuration file(s).  If you choose to follow it, you do so at your own risk.
1.   Open the "Customize User Interface" dialog by a familiar method (I like the keyboard, the command is "CUI").
2.   Switch to the "Transfer" tab.
    a. If you can't see it, expand the dialog to 2-columns by clicking the ">" button in the lower right corner.
3.   Set the left-hand column to "acad.cuix", I'll call this the "source file".
  a.  If you can not see the file, click the "Open" button and navigate to your "Application Data" folder.
    i.  Win7:  {userProfile}\AppData\Roaming
    ii. WinXP:  {userProfile}\Application Data
  b. Navigate further to the Autodesk Support folder:
    i. {Application Data}\Autodesk\ACA 2012\enu\Support
4.   Set the right-hand column to "Main Customization File", or another customization file you intend to use, the "destination file".
Transfer Tab
5.   Expand both files' "Ribbon->Panels" nodes
6.   Locate the "Home - Properties" panel in the source file.
7.   Right-click the panel and select "Copy" from the context menu
8.   Right-click the destination file's "Panels" node and select "Paste" from the context menu, it will be added to the end of the panel list.
  a.  NOTE: You may get a warning that the panel already exists. If you do, click the "Rename" button.  The new panel will most likely show up as "Copy Of Home - Properties"
Duplicate Warning
  b.  Right-Click the new panel and select "Rename".  Set the name to "Home - ACADProperties"
9.   Click the destination file's "Save" button.
10. Switch back to the dialog's "Customize" tab.
Customize Tab
11. Using the drop-down, select your destination file as the file to customize.
12. Expand the (a) "Ribbon -> Tabs -> Home-ACA"  and (b) "Ribbon -> Panels" nodes in the "Customizations…" (top-left) section.
13. Select the "Ribbon -> Panels -> Home-ACADProperties" panel, a preview will appear and the "Properties" section will populate.
14. Edit the panel's "Display Text" property, change it to "Properties"  (this is the name that will appear on the panel once it's added to the UI).
Edit Properties
15. Right-click the "Home-ACADProperties" panel in the "Customizations…" section and select "Copy" from the context menu.
16. Right-click the "Ribbon -> Tabs -> Home-ACA" node and select "Paste" from the context menu.
17. Click the "Save" button.
18. Click the "OK" button.
19. Observe your UI, the new Properties panel will appear at the right end of the "Home" tab.
20. Drag the panel to the location you would like it.
  a.  NOTE: Adding this panel to the tab causes the other panels to resize so the ribbon fits the screen/UI width.  If there are any panels that you aren't using, turn them off to allow more room for the other panels.  (I turned off the "Transparency" panel, the new "Properties" panel includes those commands in the slide-out, making it redundant.)
  b.  To turn a panel off, right-click a panel title, select Show Panels, then uncheck any panel you don't want displayed.
Now, my ribbon looks like this:
New Ribbon
I'm sure there must be an easier way to do this, but I'm okay with this for now.
Active Contributor
sgrinavi
Message 2 of 15 (6,341 Views)
Re: Get the AutoCAD "Properties" Panel into the ACA2012 Ribbon.
07-20-2011 10:19 AM in reply to: jking
OUT FREAKIN STANDING
Thanks for taking the time to make the lucid explaintion too
New Member
jad8721
Message 3 of 15 (6,282 Views)
08-02-2011 05:24 AM in reply to: jking
THANK YOU!!
This one panel, which I always use, disappeared when I installed AutoCAD Architecture 2012. It even disappeared off of my 2011 version too! I wasted 45 minutes going through help files and this useless website till I finally found an answer. I don't understand why Autodesk does not want us to have this feature or why they have to make it so difficult to get back.
mazikhelela
Message 4 of 15 (5,318 Views)
03-21-2012 04:58 PM in reply to: jking
This has been very clear and helpful, thanks!!!  :manhappy:
Active Contributor
jking
Message 5 of 15 (5,300 Views)
03-22-2012 04:38 AM in reply to: jking
Thanks!  I'm glad people are finding it useful. :smileyhappy:
Member
ericrogers
Message 6 of 15 (5,108 Views)
04-18-2012 02:59 PM in reply to: jking
I just uploaded ACAD 2012 on an new Win Vista 7 64 bit machine and the properties panel does not show up on the ribbon as it did on the Win XP version. When I try your tutorial to change the Users interface I dont get a "Home - Properties" in the source file (Main Customization File (aca.cuix) to copy. I only see:
Home 2D- Modify
Home 2D- Modeling
Home 3D- Section
Home 3D- Solid editing
Home 3D- Subobject
What else could I look for?
*Expert Elite*
David_W._Koch
Message 7 of 15 (5,092 Views)
04-18-2012 04:41 PM in reply to: ericrogers
In the tutorial provided, jking was using the ACAD.cuix file as the source file for the Home - Properties panel, and copying it to the Main Customization file (which may be ACA.cuix, or your firm's custom CUIX file).
David Koch
mazikhelela
Message 8 of 15 (5,086 Views)
04-18-2012 05:49 PM in reply to: jking
You may have to reload acad.cuix as shown on step 3.
If the path shown on step 3a  is different from what you have got, you can find the path by searching for acad.cuix in windows explorer
Member
ericrogers
Message 9 of 15 (5,084 Views)
04-18-2012 06:01 PM in reply to: mazikhelela
When I right to bring up the panels available I only get available panels called:
Layers
Draw
Modify
View
Annotation
Transparency
Inquiry
Section and Elevation
Details
Build
With the installation on my other computer I have:
Layers
Properties
Draw
Modify
Annotation
Block
Groups
Utilities
Clipboard
I don’t understand why they are different….
AutoCAD 2012 vs. AutoCAD Architecture 2012????
Member
ericrogers
Message 10 of 15 (5,083 Views)
04-18-2012 06:02 PM in reply to: ericrogers
Here is a video of what i want to see...
http://screencast.com/t/r4aWSgp9CtS
Announcements
Need installation help?
