I've got multiview blocks of casework w/ OUR casework elevations as the front view. I've created an elevation style to generate the elevations and get the desired display except for one thing.
I was having problem w/ the dimension displaying text and arrowheads appearred open. Dimensions never change and are part of the block, so I exploded dimensions and then the text and this has text displaying in the front view now.
What I still have a problem w/ is getting the arrowheads to appear closed and filled. Solid Hatch doesn't seem to work. Tried a polyline w/ 0" at the start and 1-1/2" at the end, but that appears to be unsuccessful so far.
Any other suggestions or ideas out there?
Solved by David_W_Koch. Go to Solution.
The routine that generates section/elevations does not "do" solid fills or hatches. I am surprised you got text to work (unless you used TXTEXP to explode it down to linework). The best you can do is use a line hatch with the scale set sufficiently small so that, when plotted, you get the equivalent of solid fill.
Yes, I exploded text to linework.
Hatching how you suggest sounds like an option. May try to make the arrow a block first before using it in the block of the front elevation. Perhaps that will lock it first? Just a thought.
I got this to work before...been too long to remember what I did.
Will update my progress for others interested.
