AutoCAD Architecture General Discussion
Valued Contributor
jneilon
Message 1 of 10 (429 Views)
Generate Roofs based on plines
429 Views, 9 Replies
12-10-2012 02:13 PM
I posted to AutoCAD forum not realizing there is a seperate AutoCAD architecture forum. http://forums.autodesk.com/t5/AutoCAD-2012/Generate-Roofs-based-on-plines/m-p/3730878/highlight/fals...
Same post below:
Is there a way to generate a roof based from plines? Like this but without tracing? I need to generate multiple roofs at once with the same slope ect.
Thanks.
jneilon,
after some testing I came to this code.
constraints:
a) polylines must be lwpolylines, if they are heavy polylines use the "convertpoly" command to convert the polylines into
Light (lwpolylines) before you run the code.
b) minimally tested.
Hope that helps,
Henrique
Valued Mentor
KathyMoffa
Message 2 of 10 (419 Views)
Re: Generate Roofs based on plines
12-11-2012 04:22 AM in reply to: jneilon
On the Design Palette, Right Click Roof and you will see the option to Apply Tool Properties to linework and walls.  You cannot, however, create multiple roofs from multiple closed polylines with one execution of this command.  You will need to repeat the process for each closed polyline in your drawing.
Active Member
salexandrow
Message 3 of 10 (413 Views)
12-11-2012 05:27 AM in reply to: KathyMoffa
Yes, KathyMoffa ,
I think you are right . one can select any group of wall and/or polylines.
roof would be created on the outer contour of any of this elements :
roof height would be get "electrically" from the wall height.
PS:
maybe it  is a little bit "secret" roof feaure
Valued Contributor
jneilon
Message 4 of 10 (406 Views)
12-11-2012 06:58 AM in reply to: KathyMoffa
Kathy,
Thanks this is what I was looking for. I just need to figure out how to automate multiple lines now.
Valued Contributor
jneilon
Message 5 of 10 (394 Views)
12-11-2012 08:46 AM in reply to: jneilon
Any idea if the Roofadd and RoofToolToLinework function can be scripted? I am not finding any info on these.
hmsilva
Message 6 of 10 (369 Views)
12-14-2012 09:41 AM in reply to: jneilon
jneilon,
constraints:
Hope that helps,
Henrique
dbroad
Message 7 of 10 (356 Views)
12-15-2012 07:48 AM in reply to: hmsilva
I explained the same thing in the AutoCAD forum with no response.
To OP, for customization, visit the AutoCAD Architecture Customization newsgroup.
hmsilva
Message 8 of 10 (348 Views)
12-15-2012 01:33 PM in reply to: dbroad
I did read what do you wrote in the AutoCAD forum, notice that I usually don't use use AutoCAD Architecture, and I was helping the OP with a small routine that generated rectangular roofs, after he could join the roofs with the command "union", getting the roofs he wanted.
When I started trying to use the command "RoofToolToLinework" from AutoCAD Architecture, I realized that the command only accept Lwpolylines, as you said, but I did not like the the final result, so I used the command "RoofAdd" and I realized that it would be easier to scale all entities to mm, as you said, than configure all the roof elements to meters, in the end, I used the lwpolylines in my code, because it was already too tired and very lazy, to write a few more lines of code and include the heavy polylines object it...
Cheers
Henrique
Valued Contributor
jneilon
Message 9 of 10 (328 Views)
12-17-2012 06:29 AM in reply to: hmsilva
Thanks Henrique,
This works exactly how I need it to work. Thanks for all your help.
dbroad I thought I did respond to you. Your right the lines were meters not milimeters and I did need to convert to light polylines using the convert poly command. Thanks.
hmsilva
Message 10 of 10 (326 Views)
12-17-2012 06:31 AM in reply to: jneilon
You're welcome, jneilon
Henrique
