Turn off the "Above cut plane" in the display override for this wall
escreveu na notícia da
mensagem:6301457@discussion.autodesk.com...
> Has anyone come across a way to keep gable walls from adding lines (on the
> above cut plane component layer) in a plan view?
> I need to have the layer on so as to maintain the line above openings.
> I've inculded a bmp showing the situation.
> Thanks
