I have a question regarding font styles in relation to pdf output size. Our company uses primarily romans font for notes and such and then romand or arial for tiles. Can any of these affect the file size? The cad file will be relatively small, but some of the output pdf files are quite large. On a side note. will inserting OLE objects also affect it? We sometimes insert ole's from consultants as they don't always send us the cad files.
Thank you,
Mike Lamka
Solved by dgorsman. Go to Solution.
Fonts do affect the file size and output to PDF, but only marginally.
It depends on the font you use and the PDF writer you use.
I have a specification sheet using Aerial font and the resulting PDF (autocad PDF) is 324 Kb.
That is not a large file in my opinion.
Drawings with a lot of htches create larger files and PDF output.
If I remember correctly, if TTF fonts aren't "captured" as text when a PDF is printed, the text is turned into *lots* of non-vector bits which can result in much larger files (not to mention, the text isn't searchable). OLE objects with text will likely do the same thing e.g. OLE Excel content instead of linking the workbook to an AutoCAD table.
The answer is correct but din't describe how to make sure autocad was identifying it as text. I found this thread that solve my problem. TTF files went for 5 mb to 100kb!
http://forums.augi.com/showthread.php?114557-AutoCAD-2010-DWG-to-PDF-TTF-Issue
"oksana
Did you try to change "Custom Properties" for "Font Handling" in "DWG to PDF.pc3"?
To do this go to:
PLOT > select "DWG to PDF.pc3" for Printer > select "Properties" button next to it > find and select "Custom Properties" from the list > and then "Custom Properties" button > check "Capture some" and "Edit Font List" > make sure "Arial" is checked > OK > OK > OK.
Hope this helps."
