AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Flexnet licensing crash
3 REPLIES 3
mc
Observer
650 Views, 3 Replies
I'm running AutoCAD Architecture 2012 on a 32 bit Windows 7 machine.  I'm getting a blue screen crash everytime I try to boot the software.  I've managed to isolate it to the Flexnet Licensing service.  I used msconfig to isolate it and eliminated the blue screen crashes when I disable it.  However, I can't run my Autodesk software without it.  i was able to find a hotfix for this on 64 bit systems, but I dont' see anything for a 32 bit system.  Obviously, the 64 bit fiix desn't run.  Any held would be greatly appreciated.
3 REPLIES 3
TravisNave
in reply to: mc
Post the BSOD stop error code here.  It's strange that it would be causing an error.  Very rare.
Autodesk Forums:
mc
Observer
in reply to: mc
Ended up formatting and starting fresh.  Tedious, but it worked.  Thanks for the help!
TravisNave
in reply to: mc
Sometimes you gotta go to extremes to get results!  Smiley Very Happy
Autodesk Forums:
”Boost
