I created my floor plan in in ADT 3D and need to turn it into a 2D floorplan that can be viewed and modified in AutoCAD. I would like to be able to take text, dims, walls, and doors all at the same time. Is this possible?
The best way is to use the etransmit function.
two possible ways:
1. from your project navigator, right click on the file and choose etransmit
2. from your application menu you choose AppMenu>SEND>etransmit
the next step is to configure a specific transmital setup to export as "aec exploded" and choose the version of the DWG file.
this will export the file "flatenned".
However, have in mind that: walls will be made out of lines (not polylines), hatches will be exploded.
hope it helps
regards
aghis
Aghis,
I was not able to get the way you described to work, but I just exported it as a plain AutoCAD file and it worked! My 3D floorplan is now just a 2D floorplan. The walls were changed into individual lines, but the hatched areas remained together and were not exploded. Now this floorplan can be opened and manipulated using standard AutoCAD. Thanks again for your help.
You got the right method Blaise as designed.
etransmit is to package the drawing and bits together but not ncessarilty for autocad.
The good thing about the export to, function is that it preserves your original file, not overwriting, so your 3d modelling is retained.
I know what you are saying there, I was dreading the idea of having to go in and edit that file, and now I can just make changes in my original file and re-export!
