AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Find and replace
2 REPLIES 2
Oilymo
504 Views, 2 Replies
Find and replace
Is there anyway of starting a session of AutoCAD with the find and replace fields already populated?  We have always struggled with superscript 2 and 3 when imported from MS word and have to use the find and replace;
FIND: M2
REPLACE: M\u+00b2
We used to have a VB routine that would scan the entire drawing and do the replace for us however VB failed to run on ACA 2012 and we were left with the above as a solution.
Many thanks
Ben
2 REPLIES 2
pendean
in reply to: Oilymo
You will need to customize a new solution as you had previously, there is nothing in the core program to do that.
Seek help in the Customizations forums if needed while you wait here for others to share their custom code if they can: http://forums.autodesk.com/t5/AutoCAD-Customization/ct-p/AutoCADTopic1
Victoria.Studley
in reply to: Oilymo
Hi Ben,
Dean is correct - there isn't any functionality in the program to do this at the moment. However, if you'd like to see it in a future update or release, you may want to voice that directly the Product Team, via the Product Feedback Page.
Victoria Studley
Content Experience Designer - Fusion 360
Fusion 360 | Learn & Support
Documentation | Contact Support
”Boost
