Hi All,
Within ACA 2015 I do not have the ability to hold down shift to temoprarily have a fillet radius of 0 when joining walls. It does however still work for linework. Anyone had this issue before?
Thank you,
Todd
Hi Todd,
It looks like this feature doesn't work in 2015, as it did in 2014. I've just logged the issue with our development team, and they will investigate to see if a fix or update can be provided in a future release or update.
An alternative method you could consider, while this is being looked at, is to use the Edge setting of the EXTEND command.
