AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
fillet problems
1 REPLY 1
bybame
381 Views, 1 Reply
fillet problems
please help! i have been at this for 21 hrs and still no luck 😞 i cant seem to fillet, every time i try to do so by typing in the command and selecting the line, a green 'X' would appear where both lines meet. i attached an example
1 REPLY 1
David_W_Koch
in reply to: bybame
Are you left-clicking (selecting) the second line? If the FILLET radius is set to 0, after picking the first line, and hovering the cursor over a potential second line, the green "X" appears to show the meeting point should that second line be selected. But you still have to select it to execute the command.
If the FILLET radius is not 0, instead of the green "X", you will get a preview of the arc segment that would be drawn if you selected the second line over which the cursor hovers.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
”Boost
