I have a curious issue with one drawing.
The Fillet command ignores the first selection and requires me to select the first object a second time. The roll over highlighting works, but when I select the first object, the command line issues the instruction again to select first object. I must select it a second time followed by one selection for the second object.
Other than that the command works as it should.
Another curious issue is that if I start the command but cancel it before I select anything, followed by "right click" to bring up the command again, it is under this circumstance that the first selection works as it should. I did notice that the command line indicates .fillet inlieu of _fillet.
Any thoughts would be helpful.
Patrick
Hi Patrick,
Which version of AutoCAD Architecture are you using?
Could you post a copy of the drawing for analysis? (It's easier to troubleshoot with a file to test.)
Does it only happen to the one file?
