AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
File Summary
2 REPLIES 2
274 Views, 2 Replies
File Summary
I want to insert a field from the "Documents" list of fields, see attached image "Documents Fields.jpg".  I want to insert the "Title" field, however the only place I can find "Title" in the file properties is under the tab "Summary" and I am not able to fill in any info into the space that is provided . . . I cannot input text into anything in this tab (not the author, comments, anything).  Can I change something to be allowed to input data into the "Summary" tab?  Is that the place where the "Title" field finds what it is looking for?
Thanks.
2 REPLIES 2
pendean
no attachment...
You seems to be referencing categories in DWGPROPS (the location you would fill the info in at, no where else): is that the issue?
Yes, thank you.  I've found it and works like a charm!
”Boost
