All,
Can you help? The attached file was saved and then upon reopening give a fatal error. We've tried to recover and there appears to be an error that is fixed but then ACA closes with a fatal error. Can anyone open and repair or shed some light on what's happened. The file was saved in ACA 2012 on Win 7 x64
Ben
Solved by David_W_Koch. Go to Solution.
Sign into the Subscription Center (http://subscription.autodesk.com/), then select the Technical Support link on the left column on the page. On the Technical Support page, in the Web Support area, select the Create a Support Case link.
