AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Favorite Material
4 REPLIES 4
374 Views, 4 Replies
Favorite Material
Why would my Favorites library in material browser be locked or is missing? when I drop my material in favorites I get a message stating that "Changes to the library cannot be made. The library file is currently locked or missing."
4 REPLIES 4
Laks-Autodesk
The favorite materials are stored in the FavoriteMaterials.adsklib file. Check if the file is read-only (shows a lock icon in the materials palette) or missing from its location. It should be under C:\Users\<user>\Appdata\Roaming\Autodesk\<product>\enu\Materials.
Lakshminarasimhan Seshadri
in reply to: Laks-Autodesk
I have gotten that far the file is there and it not read only. I also have full access to the directory it is in. For some reason it remains locked in my material browser.
Victoria.Studley
Hi Byron,
Which version of AutoCAD Architecture are you using?
Did you migrate the Materials Library from a previous version or add it from a different machine?
If you place the library file on your desktop, right-click and select Properties, is the option available to "Unblock..." the file? If so, try this, and replace the file in the proper location, then try again.
If the file is not blocked or read-only, and neither is the location, you may try running AutoCAD Architecture as Administrator (right-click the acad.exe file and select "Run as Administrator").
If the file is still blocked at this point, try resetting the program to defaults and/or repairing the installation.
Victoria Studley
Content Experience Designer - Fusion 360
Fusion 360 | Learn & Support
Documentation | Contact Support
in reply to: Victoria.Studley
I am using 2013, the material is OTB and I was wanting to add to the favorites in the Browser. I followed your direction guess I am going to reload now.
thanks Byron
”Boost
