AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
FATAL ERROR: Unhandled e06d7363h Exception at 75e09617h
10 REPLIES 10
Message 1 of 11
alextu
1029 Views, 10 Replies
My AutoCAD Architecture 2008 crashs with this messege FATAL ERROR: Unhandled e06d7363h Exception at 75e09617h 1-3 times a day
What is the problem?
I seached this forum, it seems something wrong with the video driver, My video driver is updated Nvidia Geforce 8600GT,
3dconfig > menual tune> I have only a direct 3D in the Driver name, no others.
I have other problem with Xref,
I can open the Xref file very fast, but when I open a file attached with the same xref file, it is very slow, it stuck about 30 seconds and then complete open.
Can someone help, please!!
10 REPLIES 10
Message 2 of 11
in reply to: alextu
This problem just started? What changed?
Dean Saadallah
http://LTisACAD.blogspot.com
Message 3 of 11
alextu
in reply to: alextu
We upgraded to Windows 7 recently,
but xref problem also happened with the computer with Vista installed.
I have no idea what happen, please see attached files.
Thank you
Message 4 of 11
alextu
in reply to: alextu
xref file attached
Message 5 of 11
in reply to: alextu
RECOVER command found 158 errors in the xref file, 2 errors in the top file:
after fixing both, they seem to be behaving here.
Dean Saadallah
Message 6 of 11
alextu
in reply to: alextu
Dean,
After use RECOVER command.
I still have probelm to open files, when I open xref itself, I haver no problem, but if I open other file (0422B81) with this Xref, my computer stuck for 30 seconds, and then open this file.
Any other solutions?
Thank you
Message 7 of 11
in reply to: alextu
Something in your setup is missing perhaps, reason for the pause: a missing
or removed PC3 file, dead drive reference, anything, There is nothing wrong
with your files.
Dean Saadallah
Message 8 of 11
alextu
in reply to: alextu
The files just a referance, My main question was FATAL ERROR: Unhandled e06d7363h Exception at 75e09617h,
What cause this error, and it happens 1-3 times per day?
Thank you
Message 9 of 11
in reply to: alextu
OK, your other topic, I can switch.
That's a generic Windows error message that means nothing to anyone not
programming Windows or AutoCAD or whatever else you have.
What you were doing at the time and what was running on your PC at that
moment might be a clue, you only said you think it is your video card.
Dean Saadallah
Message 10 of 11
in reply to: alextu
how much ram do you have and did you upgrade windows 7 to the 32 or 64 bit
version?
wrote in message news:6339969@discussion.autodesk.com...
others.
open.
Message 11 of 11
isolis
in reply to: alextu
if none of those work you might try reloading AutoCad. do not repair it, do a fresh install and see if that works. it does sound like video card or memory error.
”Boost
